• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Kevin K. · Feb 06, 2014 at 10:05 PM ·
Multiple collector versions on same server
We have installed some new servers to be used as collectors.  Since they have alot of resources, we would like to have multiple collectors installed on the same server.  We need to share these instances between Test Center Edition and our Production Edition.  Because of this, we need these collectors to be at different patch levels.  When we get patches, we patch Test Center Edition first, and then Production.  Our first attempt at doing this failed.  We installed the collectors and connected one to each DT server.  But they both got the higher patch version from Test Center, which we don't want.
Has anyone found a way around this?  We don't want to have to stand up new servers just to have different patch versions.  Any advice would be greatly appreciated.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Kevin K. · Feb 06, 2014 at 10:22 PM
Nevermind.  I figured out a way to do this.
Comment
0 Show 0 · Share
avatar image
Answer by Herwig R. · Feb 07, 2014 at 06:35 AM
Hi Kevin,
find the enclosed how to start multible collectors on a single host (use -instance parameter to handle multiple collectors).
Find the command line command for windows and a link for more details enclosed.
Best Herwig
dtcollector -service install -instance MyCollector -listen localhost:9998 -server mydynatraceserv
https://community.compuwareapm.com/community/display/DOCDT56/Collector+Configuration#CollectorConfiguration-CollectorSettings
Comment
0 Show 0 · Share
avatar image
Answer by Christian S. · Feb 07, 2014 at 12:28 PM
hi Kevin,
from my understanding you probably already used this -instance feature of the collector, right? and I also assume you're using a version previous to 5.6?
because in this case, all instances are getting the fixpack, because they share the code.
so in your scenario, you have 2 possibilities:
  • really install the collectors multiple times on this machine
  • upgrade to 5.6 and continue to use instances, because starting with 5.6 the fixpacks from instances are handled separately
best,
Christian
Comment
0 Show 0 · Share
avatar image
Answer by Rob V. · Feb 07, 2014 at 02:21 PM
In support of what Christian said: this is the approach that I've used at several customers, all of whom had this exact requirement: maintaining different dT levels for Test and Prod environments.
Comment
0 Show 0 · Share
avatar image
Answer by Kevin K. · Feb 07, 2014 at 02:54 PM
That's great to know about the 5.6 functionality.  I was doing this with 5.5.  You can't technically install this twice, since it's an MSI package.  However, here was how I was able to get this to work on 5.5.
  1. Install Collector MSI
  2. Before doing any config, copy the DT Home Directory, making an exact duplicate
  3. Use dtcollector under each DT Home Directory to install an instance under the unique directory structures
  4. After the services are created, change the user that runs the service.  Default is Local System.  Use a user account for the second collector.
Step 4 was my major hang-up yesterday.  The duplicate service won't start as the same user (Local System) like it does when they are under the same Home directory.  Once you use another user, it works great.  I was able to get both collectors to run, at different patch levels connected to two different DT Servers.  Hope this helps with anyone not using 5.6.
Comment
0 Show 0 · Share
avatar image
Answer by Steve K. · Feb 07, 2014 at 04:34 PM
Great to know that about the user accounts.  Thanks for sharing!
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
