• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Tamás V. · Mar 11, 2014 at 10:53 AM ·
dtIntrospection exception
In a 4.2 dyna environment i have a serious issue:  "Uncaught exception thrown by filter openSessionInView: java.lang.NoSuchFieldError: javax/servlet/GenericServlet.dtIntrospection" exception (you can see the whole exception at the end of the question).
It only happens if the (java) agent is active (obviously (smile)). When i remove it, there's no problem, but i want to monitor that jvm. The application is running in a Websphere App Server (other WAS+agents are working well).
I've seen a thread on this (Causes for dtIntrospection), but there was no solution (only an advice to discuss it with support).
Anyone saw this since then? Any workaround? It's kinda frustrating i can't use dyna on that server.
Tamas
The whole exception:
com.ibm.ws.webcontainer.filter.FilterInstanceWrapper doFilter SRVE8109W: Uncaught exception thrown by filter openSessionInView: java.lang.NoSuchFieldError: javax/servlet/GenericServlet.dtIntrospection
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:80)
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:195)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:91)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.SessionFixationProtectionFilter.doFilterHttp(SessionFixationProtectionFilter.java:67)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.preauth.AbstractPreAuthenticatedProcessingFilter.doFilterHttp(AbstractPreAuthenticatedProcessingFilter.java:69)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:928)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1025)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:895)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1662)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:195)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:459)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:526)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:312)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:87)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:165)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java)
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Christian S. · Mar 11, 2014 at 12:19 PM
hi Tamas,
as Andi said, this was already fixed in recent dynatrace versions, so upgrading would be a good thing, anyway. especially, because 4.2 will not be supported very much longer.
however, the Servlet Sensor should not be related to this. but the User Experience Sensor should! so if you do not need UEM, you could turn off the User Experience Sensor and you should be fine.
hope that helps, Christian
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Mar 11, 2014 at 11:15 AM
Hi Thomas
Please reach out to our support team. There might already be a fix for this problem as you are running on an older version of dynaTrace. You are right - the problem is caused by dynaTrace. So - please open a support ticket.
What you can test in the meantime is the following: I think the problem is caused by the Servlet Sensor that captures additonal parameters, e.g: HTTP Parmaeters, HTTP HEaders, ... - so - try to remove some of the parameters that you capture and see if that makes a difference. that could also be input for the support team
Andi
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
