Hi there
I am constantly seeing these in the dT Server logfile (this happen for quite a number of Incident Rules and Measures). The measures does exist and is working.
WARNING [RuleConditionConfig] incident rule condition has no related measure for measure: com.dynatrace.diagnostics.core.realtime.measures.MeasureReference@2713b504[
displayName=Leads_EJBPoolTimeout
keyId=Leads_EJBPoolTimeout
parentKeyId=Leads_EJBPoolTimeout
revision=d3e8b194-1dbe-47f0-82d9-c238750bbe74
Any ideas what this would be indicating? And how to get rid of it?
Anton
Answer by Andreas G. ·
Hi Anton
Can you try the following
a) Remove the Condition in your Incident -> Apply Changes to your system profile
b) Add the Condition again -> Apply changes
So - basically just remove and add the measure and try again
Please open a support ticket for this. I dont have any other explanation. Best is if our engineers have a look at it
