I have been trying to work with a client regarding the creation of an incident when the max connection pool was hit. Someone informed me of the “Calculate Rate” measure and I thought that would be the solution to my problem. However, now I cannot find the measure for the max connection pool, I thought it was listed here before, however as you can see in my screenshot it isn’t. Was this just a thing of my imagination or is this located somewhere else?
If there isn’t an OOB measure, can I create a custom JMX measure that will look into an mbean’s attribute and if so what are the Object and Attributes?
Answer by Chris S. ·
I believe I may have found the answer I was looking for through looking at this site
I cannot test tonight due to access rights, however I should be able to tomorrow.
Here is the specific bean and attribute I will be testing.
