• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Michael B. · May 15, 2014 at 12:23 AM ·
ADK Tagging not working
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Michael B. · May 15, 2014 at 12:25 AM
I'm attempting to use the ADK sample MultiAppDotNet.exe to test ADK tagging. The pure paths don't link up for some reason. I have both Server.run and Client.run as active and starting pure paths. The client knows it's waiting for a sync invocation to finish, but it just seems to timeout. I've linked to images that show the purepath transition: http://imgur.com/a/0BFv7
DT 5.6 current fixpack.
Comment
0 Show 3 · Share
avatar image Roman S. · May 15, 2014 at 12:36 AM 0
Share
Hi Michael,
Can you attach the system profile you are using or a session with the server and client PurePath? Did you define custom entry points for the server by any chance (asking since the screenshot shows a Server.run PurePath that would precede all the client activity)...
Best, Roman
avatar image Michael B. Roman S. · May 15, 2014 at 12:57 AM 0
Share
Your comment pointed me in the correct direction. I had Server.run as active and start a PurePath. This prevented the pure paths from linking up. Setting that to active, and adding multiply as active solved my problem. I'm surprised it's not possible to have a method participate in it's own pure path within it's process, and a remote path independently.
Another side question: If I have a client calling to the server for a long running operation, and the server calls back to the client to report progress, can I call linkClientPurePath on the server and setTag on the client to track those calls in the same purepath as well?
Thanks for your help!
Mike
avatar image Roman S. Michael B. · May 15, 2014 at 01:01 AM 0
Share
As you discovered each method can only be part of one PurePath, not mutiple and wherever the first PurePath is started is where the data is correlated.
Correct, for the scenario with client -> server -> client you will need to use the ADK twice. To make things less confusing lets call the scenario A -> B -> A.
You would use the ADK and say A is the client and B the server first, then you would use the ADK a second time with B the client and A the server. That gets you a PurePath that shows the communication correctly.
Best, Roman
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
