Answer by Kumar P. ·
I want to use parameters value for node location in the script.How I can configure it? Can any one provide me best practice which how I can use “Parameters: Substitutions by Node”
Example: I have five node locations. I want to run test every three hours by each node location in sequence but I want to make sure repeat again in sequence by node. I attached screeen shot of node location.
Location for test:
Kumar Patel
In response to your question about the sequence testing based on subsitution by node, we aren;t able to set which nodes will be tested in a specific sequence. Subsitution by node is typically used for different login credentials per node that are tested but not for the sequence which nodes will be tested in.
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Can any one can provide me javascript for select date and time? 1 Answer
Is there a way to be alerted if a Gomez script does not run and is not in maintenance? 1 Answer
New Scripting Webinar on December 17th! 1 Answer
Script Validation- regular expression - user input 1 Answer
Support for Microsoft Dynamics CRM 1 Answer
