we have a single AMD machine with a 10Gb native card. the machine is getting traffic with a smaller volume but we see a high drop rate hence a lot of data and traffic is missing.
attached are some screenshots from the research we've done.
any ideas ?
Gil.
Answer by Ulf T. ·
Hi Gil
Any reason why you run Native driver?
Using native drivers is a trade off for control versus versatility (compatibility). What I mean is that the custom driver that we write has more control in terms of how it interacts with the AMD software. We also take the liberty and peel off some things in order to get better performance.
If you can issue "lspci -v" we can check whether you NIC can use the custom driver or not.
If you need help in enabling or even forcing the driver to kick in I suggest you open a ticket with support. They shold be able to guide you through the step which shouldn't take more thatn a few minutes provided your card is supported by the custom driver that is !
Hi Ulf,
here it is:
00:00.0 Host bridge: Intel Corporation Xeon E5 v2/Core i7 DMI2 (rev 04)
Subsystem: Hewlett-Packard Company Device 18a8
Flags: fast devsel
Capabilities: [90] Express Root Port (Slot-), MSI 00
Capabilities: [e0] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
Capabilities: [144] Vendor Specific Information: ID=0004 Rev=1 Len=03c <?>
Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?>
Capabilities: [280] Vendor Specific Information: ID=0005 Rev=3 Len=018 <?>
00:01.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 1a (rev 04) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=07, subordinate=0a, sec-latency=0
I/O behind bridge: 00006000-00007fff
Memory behind bridge: f5f00000-f7ffffff
Capabilities: [40] Subsystem: Hewlett-Packard Company Device 18a8
Capabilities: [60] MSI: Enable- Count=1/2 Maskable+ 64bit-
Capabilities: [110] Access Control Services
Capabilities: [148] Advanced Error Reporting
Capabilities: [250] #19
Kernel modules: shpchp
00:01.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 1b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=14, subordinate=14, sec-latency=0
00:02.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: ef000000-ef5fffff
Prefetchable memory behind bridge: 00000000f1f00000-00000000f47fffff
00:02.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=15, subordinate=15, sec-latency=0
00:02.2 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2c (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00005000-00005fff
Memory behind bridge: f5d00000-f5efffff
Prefetchable memory behind bridge: 00000000ef600000-00000000ef6fffff
00:02.3 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2d (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=16, subordinate=16, sec-latency=0
00:03.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
00:03.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=17, subordinate=17, sec-latency=0
00:03.2 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3c (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=18, subordinate=18, sec-latency=0
00:03.3 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3d (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=19, subordinate=19, sec-latency=0
00:04.0 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 0 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 5
Memory at f4cf0000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [80] MSI-X: Enable- Count=1 Masked-
Capabilities: [90] Express Root Complex Integrated Endpoint, MSI 00
00:04.1 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 1 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 7
Memory at f4ce0000 (64-bit, non-prefetchable) [size=16K]
00:04.2 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 2 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at f4cd0000 (64-bit, non-prefetchable) [size=16K]
00:04.3 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 3 (rev 04)
Memory at f4cc0000 (64-bit, non-prefetchable) [size=16K]
00:04.4 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 4 (rev 04)
Memory at f4cb0000 (64-bit, non-prefetchable) [size=16K]
00:04.5 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 5 (rev 04)
Memory at f4ca0000 (64-bit, non-prefetchable) [size=16K]
00:04.6 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 6 (rev 04)
Memory at f4c90000 (64-bit, non-prefetchable) [size=16K]
00:04.7 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 7 (rev 04)
Memory at f4c80000 (64-bit, non-prefetchable) [size=16K]
00:05.0 System peripheral: Intel Corporation Xeon E5 v2/Core i7 VTd/Memory Map/Misc (rev 04)
Flags: fast devsel
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
00:05.2 System peripheral: Intel Corporation Xeon E5 v2/Core i7 IIO RAS (rev 04)
Flags: fast devsel
00:05.4 PIC: Intel Corporation Xeon E5 v2/Core i7 IOAPIC (rev 04) (prog-if 20 [IO(X)-APIC])
Memory at f4c70000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [44] Express Root Complex Integrated Endpoint, MSI 00
00:11.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Virtual Root Port (rev 05) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=1b, subordinate=1b, sec-latency=0
Capabilities: [40] Express Root Port (Slot-), MSI 00
Capabilities: [80] Power Management version 3
Capabilities: [88] Subsystem: Hewlett-Packard Company Device 18a9
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [100] Advanced Error Reporting
Capabilities: [138] Access Control Services
00:1a.0 USB controller: Intel Corporation C600/X79 series chipset USB2 Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 21
Memory at f4c60000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci_hcd
00:1c.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Hewlett-Packard Company Device 18a9
Capabilities: [a0] Power Management version 2
00:1c.7 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Root Port 8 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: f4d00000-f5cfffff
Prefetchable memory behind bridge: 00000000f0000000-00000000f0ffffff
00:1d.0 USB controller: Intel Corporation C600/X79 series chipset USB2 Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 20
Memory at f4c50000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=1a, subordinate=1a, sec-latency=32
Capabilities: [50] Subsystem: Hewlett-Packard Company Device 18a9
00:1f.0 ISA bridge: Intel Corporation C600/X79 series chipset LPC Controller (rev 05)
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 IDE interface: Intel Corporation C600/X79 series chipset 4-Port SATA IDE Controller (rev 05) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 17
I/O ports at 4000 [size=8]
I/O ports at 4008 [size=4]
I/O ports at 4010 [size=8]
I/O ports at 4018 [size=4]
I/O ports at 4020 [size=16]
I/O ports at 4030 [size=16]
Capabilities: [70] Power Management version 3
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ata_piix
Kernel modules: ata_generic, pata_acpi, ata_piix
01:00.0 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Slave Instrumentation & System Support (rev 05)
Subsystem: Hewlett-Packard Company iLO4
Flags: bus master, fast devsel, latency 0, IRQ 19
I/O ports at 3000 [size=256]
Memory at f5cf0000 (32-bit, non-prefetchable) [size=512]
I/O ports at 3400 [size=256]
Capabilities: [78] Power Management version 3
Capabilities: [b0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [c0] Express Legacy Endpoint, MSI 00
Kernel driver in use: hpwdt
Kernel modules: hpwdt
01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH (prog-if 00 [VGA controller])
Memory at f0000000 (32-bit, prefetchable) [size=16M]
Memory at f5ce0000 (32-bit, non-prefetchable) [size=16K]
Memory at f5000000 (32-bit, non-prefetchable) [size=8M]
Expansion ROM at <unassigned> [disabled]
Capabilities: [a8] Power Management version 3
01:00.2 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Management Processor Support and Messaging (rev 05)
Flags: bus master, fast devsel, latency 0, IRQ 16
I/O ports at 3800 [size=256]
Memory at f4ff0000 (32-bit, non-prefetchable) [size=256]
Memory at f4e00000 (32-bit, non-prefetchable) [size=1M]
Memory at f4d80000 (32-bit, non-prefetchable) [size=512K]
Memory at f4d70000 (32-bit, non-prefetchable) [size=32K]
Memory at f4d60000 (32-bit, non-prefetchable) [size=32K]
[virtual] Expansion ROM at f4d00000 [disabled] [size=64K]
Kernel driver in use: hpilo
Kernel modules: hpilo
01:00.4 USB controller: Hewlett-Packard Company Integrated Lights-Out Standard Virtual USB Controller (rev 02) (prog-if 00 [UHCI])
I/O ports at 3c00 [size=32]
Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [f0] Power Management version 3
Kernel driver in use: uhci_hcd
02:00.0 RAID bus controller: Hewlett-Packard Company Smart Array Gen8 Controllers (rev 01)
Subsystem: Hewlett-Packard Company P420i
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at f5e00000 (64-bit, non-prefetchable) [size=1M]
Memory at f5df0000 (64-bit, non-prefetchable) [size=1K]
I/O ports at 5000 [size=256]
[virtual] Expansion ROM at ef600000 [disabled] [size=512K]
Capabilities: [90] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [b0] MSI-X: Enable+ Count=64 Masked-
Capabilities: [c0] Express Endpoint, MSI 00
Capabilities: [300] #19
Kernel driver in use: hpsa
Kernel modules: hpsa
03:00.0 Ethernet controller: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet (rev 10)
Subsystem: Hewlett-Packard Company Device 3382
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f4000000 (64-bit, prefetchable) [size=8M]
Memory at f3800000 (64-bit, prefetchable) [size=8M]
Memory at f37f0000 (64-bit, prefetchable) [size=64K]
[virtual] Expansion ROM at f1f00000 [disabled] [size=512K]
Capabilities: [48] Power Management version 3
Capabilities: [50] Vital Product Data
Capabilities: [a0] MSI-X: Enable+ Count=32 Masked-
Capabilities: [ac] Express Endpoint, MSI 00
Capabilities: [13c] Device Serial Number c4-34-6b-ff-fe-af-92-00
Capabilities: [150] Power Budgeting <?>
Capabilities: [160] Virtual Channel
Capabilities: [1b8] Alternative Routing-ID Interpretation (ARI)
Capabilities: [1c0] Single Root I/O Virtualization (SR-IOV)
Capabilities: [220] #15
Kernel driver in use: bnx2x
Kernel modules: bnx2x
03:00.1 Ethernet controller: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at f2800000 (64-bit, prefetchable) [size=8M]
Memory at f2000000 (64-bit, prefetchable) [size=8M]
Memory at f1ff0000 (64-bit, prefetchable) [size=64K]
[virtual] Expansion ROM at f3000000 [disabled] [size=512K]
07:00.0 PCI bridge: Integrated Device Technology, Inc. [IDT] PES12N3A PCI Express Switch (rev 0e) (prog-if 00 [Normal decode])
Physical Slot: 2
Bus: primary=07, secondary=08, subordinate=0a, sec-latency=0
Capabilities: [40] Express Upstream Port, MSI 00
Capabilities: [c0] Power Management version 3
Capabilities: [200] Virtual Channel
Kernel driver in use: pcieport
08:02.0 PCI bridge: Integrated Device Technology, Inc. [IDT] PES12N3A PCI Express Switch (rev 0e) (prog-if 00 [Normal decode])
Bus: primary=08, secondary=09, subordinate=09, sec-latency=0
I/O behind bridge: 00006000-00006fff
Memory behind bridge: f5f00000-f6efffff
Capabilities: [40] Express Downstream Port (Slot-), MSI 00
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
08:04.0 PCI bridge: Integrated Device Technology, Inc. [IDT] PES12N3A PCI Express Switch (rev 0e) (prog-if 00 [Normal decode])
Bus: primary=08, secondary=0a, subordinate=0a, sec-latency=0
I/O behind bridge: 00007000-00007fff
Memory behind bridge: f6f00000-f7ffffff
09:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
Subsystem: Intel Corporation Gigabit ET Quad Port Server Adapter
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f6ee0000 (32-bit, non-prefetchable) [size=128K]
Memory at f6800000 (32-bit, non-prefetchable) [size=4M]
I/O ports at 6000 [size=32]
Memory at f67f0000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=10 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 00-1b-21-ff-ff-7e-b2-90
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Kernel driver in use: igb
Kernel modules: igb
09:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 30
Memory at f67c0000 (32-bit, non-prefetchable) [size=128K]
Memory at f6000000 (32-bit, non-prefetchable) [size=4M]
I/O ports at 6020 [size=32]
Memory at f5ff0000 (32-bit, non-prefetchable) [size=16K]
Kernel modules: igb
0a:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 26
Memory at f7fe0000 (32-bit, non-prefetchable) [size=128K]
Memory at f7800000 (32-bit, non-prefetchable) [size=4M]
I/O ports at 7000 [size=32]
Memory at f77f0000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [140] Device Serial Number 00-1b-21-ff-ff-7e-b2-94
Kernel modules: igb
0a:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at f77c0000 (32-bit, non-prefetchable) [size=128K]
Memory at f7000000 (32-bit, non-prefetchable) [size=4M]
I/O ports at 7020 [size=32]
Memory at f6ff0000 (32-bit, non-prefetchable) [size=16K]
Kernel modules: igb
20:00.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port in DMI2 Mode (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=2b, subordinate=2b, sec-latency=0
20:01.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 1a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=24, subordinate=24, sec-latency=0
20:01.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 1b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=25, subordinate=25, sec-latency=0
20:02.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=23, subordinate=23, sec-latency=0
20:02.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=26, subordinate=26, sec-latency=0
20:02.2 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2c (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=22, subordinate=22, sec-latency=0
20:02.3 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2d (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=27, subordinate=27, sec-latency=0
20:03.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=21, subordinate=21, sec-latency=0
20:03.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=28, subordinate=28, sec-latency=0
20:03.2 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3c (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=29, subordinate=29, sec-latency=0
20:03.3 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3d (rev 04) (prog-if 00 [Normal decode])
Bus: primary=20, secondary=2a, subordinate=2a, sec-latency=0
20:04.0 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 0 (rev 04)
Memory at fbff0000 (64-bit, non-prefetchable) [size=16K]
20:04.1 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 1 (rev 04)
Memory at fbfe0000 (64-bit, non-prefetchable) [size=16K]
20:04.2 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 2 (rev 04)
Memory at fbfd0000 (64-bit, non-prefetchable) [size=16K]
20:04.3 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 3 (rev 04)
Memory at fbfc0000 (64-bit, non-prefetchable) [size=16K]
20:04.4 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 4 (rev 04)
Memory at fbfb0000 (64-bit, non-prefetchable) [size=16K]
20:04.5 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 5 (rev 04)
Memory at fbfa0000 (64-bit, non-prefetchable) [size=16K]
20:04.6 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 6 (rev 04)
Memory at fbf90000 (64-bit, non-prefetchable) [size=16K]
20:04.7 System peripheral: Intel Corporation Xeon E5 v2/Core i7 Crystal Beach DMA Channel 7 (rev 04)
Memory at fbf80000 (64-bit, non-prefetchable) [size=16K]
20:05.0 System peripheral: Intel Corporation Xeon E5 v2/Core i7 VTd/Memory Map/Misc (rev 04)
Flags: fast devsel
20:05.2 System peripheral: Intel Corporation Xeon E5 v2/Core i7 IIO RAS (rev 04)
Flags: fast devsel
20:05.4 PIC: Intel Corporation Xeon E5 v2/Core i7 IOAPIC (rev 04) (prog-if 20 [IO(X)-APIC])
Memory at fbf70000 (32-bit, non-prefetchable) [size=4K]
Answer by Ulf T. ·
My bad Gil - I asked you to do the wrong command :-|
What I needed was"lspci -nn|grep Ethernet"
Hopefully you will also get a shorter list then - again sorry for the mistake on my behalf.
03:00.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet [14e4:168e] (rev 10)
03:00.1 Ethernet controller [0200]: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet [14e4:168e] (rev 10)
09:00.0 Ethernet controller [0200]: Intel Corporation 82576 Gigabit Network Connection [8086:10e8] (rev 01)
09:00.1 Ethernet controller [0200]: Intel Corporation 82576 Gigabit Network Connection [8086:10e8] (rev 01)
0a:00.0 Ethernet controller [0200]: Intel Corporation 82576 Gigabit Network Connection [8086:10e8] (rev 01)
0a:00.1 Ethernet controller [0200]: Intel Corporation 82576 Gigabit Network Connection [8086:10e8] (rev 01)
Answer by Ulf T. ·
Hi
The first card there - Broadcom (I suppose this is the onboard) is not supported with the custom driver, but I guess you use it for communication.
The other card - Intel (8086:10e8) should be supported with the custom driver, both in 32 and 64 mode .
My suggestion is to check that you are not capturing/decoding on Broadcom and then force the Intel card to use the custom driver.
If it fo some reason doesn't work to get this done through the menus, open a ticket with support as you need to edit a few file by hand
