question
Patrick Y. avatar image
Patrick Y. asked ·
How to mask a parameter with the colon parameter?
Hi, In the sequenced transactions > parameter masks section of the AMD configuration, we are able to mask any parameter (as to encrypt password for instance). I am trying without success to hide the following parameter: login:loginForm:password=***** I believe there are some characters that are not supported (like the ':')? How to do it then?
I already tried:
password=*,
login:loginForm:password=*,
login\:loginForm\:password=*,
login%3AloginForm%3Apassword=*
Patrick
ads
Adam P. avatar image
Adam P. answered ·
This is a limitation of the current design. While it cannot be easily removed due to potentially large impact, the first of the masks you mentioned (password=*) should work fine.
Could you provide the configuration and a sample HTTP request containing data to be masked (e.g. with the actual password manually masked by the customer)?
1 comment Share
Hi Adam,
I am not on site anymore so can't provide any of your requested samples.
Indeed the password=* should work fine, but that was not the case. Tried different things without success and the content-type monitoring should cover this request.
Patrick
0 Likes 0 · ·
Adam P. answered ·
Patrick,
Indeed, colon is not supported in here.
Please log a support ticket so we can work o n this with Dev.
Share
