question
Chuan W. avatar image
Chuan W. asked ·
IBM CICS decode
anyone had try develop a decode for IBM CICS ?
universal decode
Chuan W. answered ·
Thanks a lot. o well maybe I can advise customer whether it there any plan to move to use TCP instead of UDP which I understand the SNA too can support.
Share
Ulf T. avatar image
Ulf T. answered ·
Hi Chuan.
It looks like you have come to a dead end. If it hadn't been UDP, you could have used the Universal Decode but that requires TCP.
In the predecessor to DCRUM we had a SNA decode, but frankly, there's isn't that much of that protocol in the open today. Most of the traffic is through SOAP/XML over HTTP or MQ. Rarely do actual SNA traffic pass by a AMD.
The HIS can do TCP/IP too but in your case it's not the case, unfortunately.
Share
Chuan W. answered ·
Hi all, apologize for the late reply. I just back with more information as I am performing a DCRUM poc for government.
Address to Roman question, the customer IT Ops is looking at only agentless solution as putting agent into mainframe would increase the scope which IT Ops cannot manage and would make the whole PoC scope difficult to manage as it would require another team. furthermore, it is a production mainframe, planting agent into mainframe would really complicate alot of things.
Address to ulf, as there's communication between the Web/App Server directly to the mainframe using MS HIS which talk using SNA traffic. However, as this is a Ethernet based network. The SNA traffic is delivery through using UDP protocol. In the PoC, I am able to capture the UDP traffic communciation between the Web/App -> Mainframe but due to the UDP as sessionless protcol, there's not much value. Hence, if we can decode the UDP and SNA traffic which I am not sure would provide additional insight and value to customer ?.
Share
Ulf T. avatar image
Ulf T. answered ·
Hi Chuan
I don't think the CICS traffic leaves the mainframe or do you actually have SNA traffic in your network?
Share
Roman S. avatar image
Roman S. answered ·
If you need insight into the Mainframe - have you looked at the agent-based approach that AppMon has for CICS & IMS?
Share
