question
Martin V. avatar image
Martin V. asked ·
Is it possible to define the "Other data services" link to the ADS using the FQDN instead of the IP Address?
Is it possible to define the "Other data services" link to the ADS using the FQDN instead of the IP Address? Likewise, from the ADS returning to the CAS?
nam servernamads
1 Answer
Tomasz W. avatar image
Tomasz W. answered ·
It seems to be possible. FQDN must be entered as the value of "Address" field when adding a device to RUM Console. After that when farm is created it will be used as node's address and the link to 'other data services' will use it instead the IP.
If you already have the environment configured please use "edit" functionality in RUM Console on the devices list and set the "Address" field using FQDN.
Share
