Can I increase the RUM Console timeout?
Answer by Tomasz L. · Nov 16, 2017 at 11:46 AM
In version 2017 you can change RUM Console session timeout by changing the value of session.timeout property in console.properties file. RUM Console service restart is required for change to be applied.
Answer by John L. · Jan 31, 2017 at 08:03 PM
I believe you can.
Open the administration console -> General properties.
Search for Timeout in the screen. Try changing the "HTTP_SESSION_TIMEOUT" setting.
That setting only seems to control the CAS/ADS. I have the timeout set to 120 and that seems right. I have not timed it, but the RUM console seems to timeout in 15 minutes or so.
I'm totally sorry - you did say RUM Console in the title. My mind flipped to CAS.
You can try changing (navigate the path to where you installed the console):
C:\Program Files\Dynatrace\RUM Console\workspace\configuration\httpclient.properties.
Take a look at the "http.client.connectionTimeout=" setting.
Try changing that. Please make sure you keep the current value somewhere in case that is not the correct place to change it.
Answer by John L. · Jan 31, 2017 at 08:54 PM
I've been looking around the configuration and can't find where you might change it. I found a post stating:
"Session inactivity timeout for Console is set to 20 minutes. You cannot change it."
We may need to wait for someone from development to answer this question.
Answer by John L. · Feb 02, 2017 at 02:53 PM
So this did the trick?
Changing the value of "http.client.connectionTimeout=" did the trick.
Answer by Tomasz N. · Nov 30, 2018 at 02:19 PM
It's a bit old thread, but just that we have full set of info in one place - in RUM Console 18.x the session timeout is configurable in "c:\Program Files\Dynatrace\NAM\Console\workspace\configuration\console.properties" file, property
session.timeout=20
(20 minutes is the default setting).
Best Regards,
Tomasz
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Software Services name suffix 2 Answers
RUM Console traces are not showing any traffic, but in CAS I can see there was traffic. 1 Answer
transactions appear and disappear 1 Answer
[12.4.10] WCF Net.TCP Software Service? 4 Answers
RUM Console Alerts configuration CONNECTION IDLE [Trap Recipients] 1 Answer
