question
benjamin j. avatar image
benjamin j. asked ·
DMI Filtering bar - Load minimised
Hello, does anyone know of a way to load the filtering bar in DMI to be minimsed by default?
Users would therefore expand the bar if they wanted to apply a filter across the DMI report.
Due to the number of items in the bar, they can take up a lot of space in the DMI report when they load expanded by default!
Cheers
Ben
nam servernam
1 Answer
Barbara Z. avatar image
Barbara Z. answered ·
An option to load filtering bar section minimized will be available in the new version.
2 comments Share
Excellent, thanks! Which release number is it targeting?
0 Likes 0 · ·
This will be available in the 2017 April release.
0 Likes 0 · ·
