question
Friederike T. avatar image
Friederike T. asked ·
Sequence Transaction with regular Expression
I'm trying to create some sequence transactions for a http service. there is one transaction that can start from mulitple URLs which only differs in a slightly different parameter like:
URI 1a: http://hostname.com/start.htm?Para1=ABC
URI 1b: http://hostname.com/start.htm?Para1=ABD
I tried to create a sequence transaction with a starting point defined like:
regex:hostname.com/start.htm?Para1=AB*
But this is never matched. In the documentation
https://community.dynatrace.com/community/display/DCRUM124/Adding+transactions+for+a+range+of+AMDs it is described that we can use * in a HTTP transaction for saying "any number of any character". Did anyone tried this with success?
nam serversequence transactions
1 Answer
Janusz D. avatar image
Janusz D. answered ·
Hi Friederike
But either you use regex or not.
try something like
regex:hostname\.com\/start\.htm\?Para1=AB.
or
1 comment Share
Thanks Janusz, didn't noticed that there is a difference between regex usage an just "masking"
0 Likes 0 · ·
