question
Mark G. avatar image
Mark G. asked ·
DCRUM Sequence Transaction with similar starting operations
Hello All,
In DCRUM with Sequence Transactions. Can we have Sequence Transactions that have similar starting Operations? And AMD will be able to determine to which Sequence Transaction the flow belongs to?
For example if you have defined two sequence transactions:
Sequence Transaction 1
- Operation A
- Operation B
- Operation C
Sequence Transaction 2
- Operation A
- Operation D
- Operation E
When the AMD sees the flow A, D, E. Will it be able to determine Seq Transaction 2 was performed. Or does it think it was Seq Transaction 1 and it was aborted at the second operation, because it was not B.
Does anyone know how DCRUM will work when there are several sequence transactions that have the same starting operation?
Kind regards,
Mark
Lukasz K. avatar image
Lukasz K. answered ·
DCRUM can handle two different sequence transactions starting from the same operation. It will match the best one.
It will not work if you have one transaction embedded in the other one:
Sequence Transaction 1:
- Operation A
- Operation B
- Operation C
- Operation D
Sequence Transaction 2:
- Operation B
- Operation C
Then we don't know which operation to report.
Share
Ulf T. avatar image
Ulf T. answered ·
Thanks @Lukasz K.
But will it then report both as failed or what will it report?
Share
Ulf T. avatar image
Ulf T. answered ·
Hi Mark
Have you tried this using the "Transaction Recorder"?
But your question is valid - what if all transaction started with Operation A and then something else, do all of them but 1 fail?
1 comment Share
This is exactly what I need to know now :-)
0 Likes 0 · ·
