question
Frans S. avatar image
Frans S. asked ·
12.4: User help Menu servlet menu
CAS 12.4 brings the Help Menu, the User (icon) menu on the right upper corner, that opens when clicked. I would like to have more information how to modify the content of the menu (items), add/remove/construct...
Also it would be very desirable if the rights to what user(groups)/roles the menu items are shown could be controlled. But I think that requires an enhancement request.
So far I found out that servletsmenu-100-hcbs.properties and servletsmenu-999-hcbs.properties config files contain the options shown. Commenting them out works (but results in a stack of exception errors in the server log at startup).
dashboardnam server
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
please note that modifying servletsmenu-*.properties files is not officially supported and those files will be overwritten during upgrade.
We have provided an official way to modify reporting part of the menu: https://university.dynatrace.com/videos/193560101...
Also see documentation:
https://www.dynatrace.com/support/doc/nam/cas-and-reporting/reports/using-cas-reports/#customizing-the-reports-menu
There are currently no plans to enable customization of other menu entries.
Share
