question
Wong S. avatar image
Wong S. asked ·
Multiple CAS connect to one Synthetic Agent Manager
Hi there,
I have a use case to have a Single Shared Enterprise Synthetic Agent Manager supporting multiple customer central analysis servers. The idea is to have it as a centralized agent management for multiple customers with dedicated agent(s) in each customer sites. However, understand from CAS configuration perspective is just adding that Enterprise Synthetic Agent Manager as a data source. this means CAS would have pull in all data which the agent manager managed. Hence, question is there a way for us to pick and choose which agents to be send over the CAS. i.e agents X,Y belong customer A so CAS A will only pull agents X,Y synthetic data.
Base on doc , I would assume that customer A CAS would pull all the agent data manage by the agent manager but from report/dashboard/alert we will configured to show customer synthetic agent data only and trigger alert only to the designated customer
Anyone have setup such scenario before ?
Cheers,
nam serveresm
1 Answer
Carol O. avatar image
Carol O. answered ·
Hi, Chuan. You are correct that each customer's CAS would pull all the agents' data managed by the Agent Manager. Thanks!
Share
