question
Elena H. avatar image
Elena H. asked ·
Differences between Network baselines and Network with baselines tabs on Metric Chart - Network dashboard
Can anyone tell me the differences between "Network baselines" tab and "Network with baselines" tab on Metric Chart - Network dashboard?
I opened the two reports and it seems the field are the same.
What is it shown on each other?
Elena
dashboardnam server
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Take a look at this comparison below:
Network - shows charts with current data for the given time range.
Network baselines - shows charts with data rendered from baseline data view.
Network with baselines - shows both types of charts one after another.
Share
