question
Zbyszek C. avatar image
Zbyszek C. asked ·
CSS can't import an LDAP group with a name starting with ! (exclamation mark)
I'm moving an old instance of DC RUM to a new hardware. Unfortunately, despite the LDAP integration configuration is exactly the same as on the old instance, CSS cannot import groups which names start with "!", for example !ADMIN_IT. Is it a bug or I'm doing something wrong?
css
1 Answer
Tomasz L. avatar image
Tomasz L. answered ·
Which version do you have? What error do you receive?
1 comment Share
It's 12.4.14.
0 Likes 0 · ·
