As you can see, the same graph, the same time frame (last 7 days), just that 1st one is daily resolution while 2nd one is using hourly resolution, but the average is different. Anybody knows why?
Answer by Sebastian K. · Jun 14, 2018 at 07:54 AM
The summary data presented on the chart is calculated based on the data presented on the chart. That is why when your resolution changes the average values of operation time changes in each "time bucket". The reason for that is that the operation time is the weighted average of operation time against number of operations.
Let me illustrate that. In the image below there are operation times for the same period (see report https://apm.gdn.demo.dynatrace.com/LSServlet?lsEn... (demouser / demouser123) ) but with different resolutions; the smallest table simply shows the average value for the given time without split into time buckets.
Now, I exported the data into spreadsheet and did some calculations below. See how average of averages differs from the correct value being the "sum of operation time" divided by "sum of operations". And this is the value you see in the smallest table, where there is is no split by time.
How to fix your chart? Since DC RUM 2017 you can have multiple benchmarks and can attach additional data with the same filters and metrics, but without time dimension. See the aforementioned reported for details:
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Several Report Questions 5 Answers
DCRUM CAS Cluster stop and startup order 2 Answers
Location has # of users, but many show no requests 1 Answer
Oracle forms modules not available in CAS after 24 hours 7 Answers
CAS User Options - Aggregation 2 Answers
