question
lazaro c. avatar image
lazaro c. asked ·
DCRum upgrade
Hi all,
I would like to upgrade / fixpack my environment to version 12.4.15. Currently the components are to the following versions:
AMD = 12.4.3
CAS = 12.4.2
Rum Console = 12.4.2
I would like to avoid upgrading AMD because it is shared with another customer, who has the CAS and Rum Console version 12.4.11.
Is it possible or am I obliged to upgrade this component?
Is version 12.4 still supported by dynatrace?
Regards
Perez
upgrade
1 Answer
Przemyslaw T. avatar image
Przemyslaw T. answered ·
Lazaro,
Release 12.4 is no longer supported and therefore we recommend that you (and the other customer sharing data from the same AMD) consider migration to 2017 SP5 release. I suggest opening a migration ticket so we can advise you on the best migration approach.
Upgrading your existing 12.4.2/12.4.3 components to 12.4.15 is may not work properly with report server components being at 12.4.11 - those would have to be upgraded to 12.4.15 first.
Also if you're still running classic AMD, please be aware the 2017 AMD there is a new AMD architecture (so called high-speed AMD) and in order to migrate to this release, you'd need RHEL 7 OS and follow this AMD migration procedure.
1 comment Share
Hi Przemyslaw,
thanks for the very fast and exhaustive response.
I will program the upgrade according to your advice.
Regards
Lazaro
0 Likes 0 · ·
