question
jose r. avatar image
jose r. asked ·
updating DCRUM 2017 SP6
I am planning update Dcrum 2017 sp5 to dcrum 2017Sp6. Should I consider something special? or running the installers is enough?
Thanks and regards
Jose A
namupgrade
1 Answer
Przemyslaw T. avatar image
Przemyslaw T. answered ·
Hi. It’s pretty straightforward. Download SP6, stop services, upgrade components and start them up. Upgrade components in this order: RUM console first, then CAS server(s), ADS servers(s) and your AMDs at the end.
Share
