question
Babar Q. avatar image
Babar Q. asked ·
Save as PDF Scheduled Task
Dear All,
Can we make a schedule to save a report in the PDF form instead of sending by email?
Babar
dashboardnam
Andrzej L. avatar image
Andrzej L. answered ·
Yes. Please check the file tasks-examples.xml-examples in the config directory. In the file there is an example of scheduled task to export file in pdf format.
1 comment Share
Hello @Andrzej L.
Thank you for the prompt response.
Which parameters are mandatory to change?
How to schedule the report after mandatory changes?
<tasks>
    Example of export of DMI report
    <task ID="SaveReportCommand" name="SaveReportCommand" periodType="DAY" period="1" timeLine="SERVER" offsetTime="00:30" timeout="01:00" >
        <command ID="0">
            <class>SaveDmiReportCommand</class>
			<!-- mandatory parameters -->
            <param name="report">Software Services</param>
            <param name="out">{delta.root}{file.separator}exportReports{file.separator}Software Services [datetime].pdf</param>
            <param name="user">Batman</param>
			<param name="format">pdf</param>
			<!-- optional parameters -->
			<param name="timeFormat">HH:mm:ss.SSS</param>
			<param name="dateFormat">dd/MM/yy</param>
			<param name="language">ja</param>
			<param name="decimalSeparator">,</param>
			<param name="groupingSymbol"> </param>
			<param name="timeZone">US/Central</param>
			<param name="locale">fr_FR</param>
			<param name="customParameters">FILTER_appl=SAP*&timeRange=7d&timeResolution=DAY</param>
        </command>
     </task>
Babar
0 Likes 0 · ·
Babar Q. answered ·
Hello @Frans S.
I just want to save a scheduled report on the CAS server. Below are the examples of your modified script and the script is available for me in the task-examples.
If I use your script and just change the DMI report name and offsetime then where it is going to store the .pdf file?
<task ID="MO_PdfMail_Test" name="MonthlyOverview-PdfMail_Test" periodType="MONTH" period="1" timeLine="SERVER" offsetTime="00:04:05" timeout="00:10">
    <command ID="1">
      <class>adlex.delta.scheduler.command.SaveReportCommand</class>
      <param>/LSSaveAs?lsAction=Saveas&format=pdf&lsEntryName=Monthly+Overview+Application+Service+Management+-+Scheduled&FILTER_bgParent=Test</param>
      <param>{delta.root}{file.separator}SchedRpt{file.separator}Monthly_Transaction_Overview_Test.pdf</param>
    </command>
        <command ID="0">
        </command>
     </task>
Babar
Share
Frans S. avatar image
Frans S. answered ·
Yes, like Andrzej says.
Also have a look at this topic, where examples are given:
https://answers.dynatrace.com/questions/211758/daily-report-add-datetime-to-report-name.html?childToView=211995#answer-211995
1 comment Share
Hello @Frans S.
Thank you for the shared link. I just want to schedule a daily report in the .pdf format and save on the CAS server.
Should I make a copy of the tasks-examples and save it in the .xml format after removing the additional information in the file except the task ID="SaveReportCommand"?
What else I will have to change in the below?
        <command ID="0">
        </command>
     </task>
Babar
0 Likes 0 · ·
