question
Shilpi M. avatar image
Shilpi M. asked ·
DCRUM 2017 SP5 - Alert Suppression
Hello Experts,
I am using DCRUM 2017 SP5. For ticket generation using DCRUM email alert, I need to check how can an alert be suppressed for next 24 hours?
For example if monitored application's performance is below 80% with performance affected user more than 50 for 6 intervals, an alert should be generated. But once generated, the alert should not re-generate for next 24 hours (288 intervals).
Please let me know if it is feasible or any other condition of delayed consecutive alert can be achieved.
Shilpi
alertingnam servernam
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Shilpi M.
I guess you can use the propagation settings of 'Reissue every n minutes' to specifies the number of minutes that must elapse following the last notification of the alert before the alert notification is re-issued.
https://www.dynatrace.com/support/doc/nam/referenc...
Babar
Share
