question
Juan U. avatar image
Juan U. asked ·
I have an application very similar to ISO 8583 but one of the nodes is AS400, therefore the tcp payload is sent in EBCDIC format. It would be possible to implement the Universal Decode in this case ?
universal decode
1 Answer
Kris Z. avatar image
Kris Z. answered ·
Sure. You just need to convert EBCDIC to ASCII within the decode script, then it will be easier to handle all fields' data. I wont have a reference to a converter library like that for LUA, but I'm sure someone somewhere has already developed one.
Share
