question
Ingrid R. avatar image
Ingrid R. asked ·
How to apply applying filter section in the same grafh selected?
I am creating a custom DMI report to shows in a graph, the status of the Software service of the last 5 hours.
it vae tiles, tables in diferent sections of performance, health and slow top operations. I have created applying filter, which allows you to select a time from the health graph, and changes all the parameters. but I can not change the same health graph in time.
I do not know how to change the EIAP Health chart, and show that time, in 5-minute periods
namreports
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
I think I know what you are after. I would suggest to use a "self-link" instead of Apply filter. A self link is a link to the same report - which by default makes sure that unless you provide some extra parameters the report will not change. With that, you can for example tell in the link definition to carry over time from the row (or column in chart) and apply as a time range in the destination report.
See this example report: https://apm.gdn.demo.dynatrace.com/LSServlet?lsEn... (guest / guest)
Share
