question
Swati B. avatar image
Swati B. asked ·
DHE Cipher
HI , I have an application with DHE cipher. Can someone help me know which analyzers can be used to monitoring availability and performance for this? As per my understanding DHE is not supported and no data will be decrypted. But I am only looking to capture performance and availability status.
NAM 2018
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Swati B.
In this situation, you will have to use the SSL analyzer.
"Gives you insight into the performance of the SSL exchanges without actually decrypting the traffic. The analyzer provides the metrics of the SSL handshake timing and errors. We recommend to use it when you're not able to add your SSL keys to the NAM Probe or use a cipher we're not capable of decrypting, for example of the Diffie-Hellman based ciphers.
Babar
Share
