question
takayuki i. avatar image
takayuki i. asked ·
"Hardware changes detected ..." error when restarting OS
I will post for the first time.
Although the hardware (NIC: Label3) was not changed, an error message was output after the AMD server was restarted and data collection stopped. As a result, Label1 and Label2 data can no longer be collected. The hardware of Label1 and Label2 has not changed.
I want to know the following.
1. Why Label3 hardware recognition changed after AMD server restart
2. Why Label1 and Label2 can no longer collect data
cmd: rtminst
Network setup:
Default gateway: xx.xx.xx.xx
Hostname: AAAAA
AMD type: Probe HS
Driver type: native
| | Aval. | Link | | | Link | IP /
# | Name | HW type | driver | param. | Mode | Traffic | det. | Label
1 | aaa1 | e1000e | Native | default | Comm. | In | Y | AAAAA
2 | aaa2s0 | igb | Native | default | Capt. | In | Y | Label2
3 | aaa4s0! | 8139too | Native | default | Capt. | In | Y | Label3
4 | aaa5s0 | e1000e | Native | default | Capt. | In | Y | Label1
(*)-changed since last refresh
port type colors: capture, communication, IP assigned, IP DHCP, other
-Problems:
Error: Hardware changes detected aaa4s0: 10ec: 8169-> 10ec: 8129, use M to reconfigure ports
Best Regards,
Takayuki Iida
nam
1 Answer
Erik S. avatar image
Erik S. answered ·
Did you recently update your RHEL/CentOS? There is a known issue with one of the updates that reshuffles how the networking hardware is identified.
-- Erik
Share
