question
Wai C. avatar image
Wai C. asked ·
Unable to disable alert in RUM Console
Anyone experience this before?
I disable the alert, then of course the 'publish configuration' won't be grey-out anymore.
I click on publish configuration, for a few seconds it seems to work. Then after that it turns back from grey-put to blue color, and the configuration never get published, the alert is still enabled.
It is like this no matter how many times I tried.
Anyone has any idea what to do next?
Best Regards,
Wai Keat
nam console
1 Answer
Tomasz L. avatar image
Tomasz L. answered ·
Which version is it? What does device status say? It should show you detail "Sent configuration" "Read configuration" status.
Share
