question
shyamala p. avatar image
shyamala p. asked ·
how to configure alert when benchmark value is no longer exceeded
hi All,
We have configured a alert, it sends an notification when it exceeds bench mark 200%... but here we need to configure one more alert when its come to below 200%.Is there any possibility to create such alert?
Shyamala
nam console
shyamala p. answered ·
Application team need alert if value goes to less than 200% rather than cancel event in DCRUM
1 comment Share
In such case, the idea which you suggested previously, two separate alerts seems to be the best solution. One alert for being above 200%, another one for being below 200% and the same, simple version of propagation settings:
The screenshot is made with DC RUM 17 version, but the same solution would work also for NAM 2018/2019
Best Regards,
Jacek
0 Likes 0 · ·
hi Jacks,
Can you explain how to do it DCRUM 17 instaed of NAM
1 comment Share
I would try with very similar configuration:
By the way, I wanted to encourage you to migration to NAM 2019, there were plenty of improvements there, in particular in alerting area. I'm pretty sure that your work will be much easier with NAM 2019
BR,
Jacek
0 Likes 0 · ·
Jacek J. avatar image
Jacek J. answered ·
Hi Shyamala,
Yes, it is possible to create such alert in NAM. In fact configuration is very similar to alert handling case of exceeding 200% threshold. I don't know which version of NAM do you have, so here is example configuration of alert to be triggered when volume for Software service HTTP drops below 200% of baseline in two versions, one created with NAM 2018/2019 and another one created with DC RUM 17
NAM 2018/2019:
DC RUM 17:
Best Regards,
Jacek
2 comments Share
Thanks Jack for responding
for example... i have alert which trigger when benchmark values exceeds 200% after some time value goes below 200% then immediately another alert should trigger...I am not sure how can we interlink these alerts?
Will the above suggestions works as i expected?
0 Likes 0 · ·
You can use two separate alerts with conditions: "value is more than 200% of baseline" in 1st and "value is less than 200% of baseline" in 2nd, but I think there is easier way to achieve the same goal. How about adding condition for Cancel event in your first alert instead of creating two alerts? Something like this:
My advice would be to start with such configuration and maybe do some experiments (perhaps you don't need reissues or you want them less often ?)
Best Regards,
Jacek
0 Likes 0 · ·
