question
YC M. avatar image
YC M. asked ·
What is default connection port between DCRUM CAS and SQL server
My company will remediate TLS 1.0 and TLS 11 to access SQL Server. How can I check which protocol we are using by CAS/ADS to connect SQL server? And how can I change it?
We are using DCRUM 2017 SP 5 now.
YC
nam
1 Answer
Wai C. avatar image
Wai C. answered ·
Microsoft SQL should be listening on port 1433.
If you want to change it, you should configure it in Microsoft SQL, not NAM there.
3 comments Share
This is correct, 1433 is default port for MS SQL server, but of course it might be changed.
You are asked to provide port during NAM server installation procedure. Please, take into account, that after changing the port on MS SQL side, you need to update configuration on NAM server side as well.
Best Regards,
Jacek
0 Likes 0 · ·
Do you know where I can check which TLS version I'm using?
YC
0 Likes 0 · ·
Hello @YC M.
The following link is a summary of network ports and protocols for various communication channels required for NAM Server, DC RUM 2017 ADS, NAM Probe, NAM Console, TCAM, and other components of NAM.
https://www.dynatrace.com/support/doc/nam/deployment-security-guide/network-ports-and-protocols/
Babar
0 Likes 0 · ·
