question
YC M. avatar image
YC M. asked ·
How can I know which version of TLS I'm using for DCRUM communicate with SQL serve?
Like TLS 1.1 or TLS 1.2. I want to limit DCRUM only use TLS 1.2 connect to SQL server.
YC
nam
Erik S. avatar image
Erik S. answered ·
The TLS version used is generally controlled by the server, not the client.
This page (external site) includes the instructions to configure the SQL server to only use TLS 1.2:
http://dba-datascience.com/ssl-or-tls-encryption-on-sql-server/
-- Erik
Share
Babar Q. avatar image
Babar Q. answered ·
Hello @YC M.
It is an optional feature during configuration whether to use SSL in communication between the NAM Server and SQL Server.
Babar
Share
