question
Toshimasa S. avatar image
Toshimasa S. asked ·
Probe 2018 installation problem
I'm trying to install probe2018 in CentOS7.4 environment. But it failed with an error. What is the problem?
The installation command is
    ./upgrade-amd-amdos7 ........bin --automatic --licenses-type capacity
nam probe
1 Answer
Przemyslaw T. avatar image
Przemyslaw T. answered ·
You are missing gcc, make and createrepo packages - you need to install those and then test your system with
./upgrade-amd-amdos7-x86_64-ndw-18-00-06-0083-b001.bin --test-system
prior NAM Probe software installation to make sure no other packages are missing.
4 comments Share
Thank you for reply.
"gcc, make and createrepo" are all already installed.But an error occurred.
I think there is no problem.
0 Likes 0 · ·
Please follow this troubleshooting case then.
0 Likes 0 · ·
It was solved with this troubleshooting.
Thank you very much.
0 Likes 0 · ·
You are welcome.
ps. Why don't you use the latest available version 19.02 instead? Since it's a new NAM Probe installation.
0 Likes 0 · ·
