question
Wai C. avatar image
Wai C. asked ·
How to change aggregation of metrics in NAM?
For Example, I look at the chart of HTTP 404 error using last 3 month with monthly resolution.
So what I see are 3 bar, where each bar shows the SUM of HTTP 404 error for that month.
What if I want each bar to show AVERAGE HTTP 404 error per day instead of SUM?
I know I can knew the answer by change the monthly resolution to daily resolution to see 30/60/90 bar. But right now I need to achieve this by 3 bar only.
Best Regards,
Wai Keat
configurationdashboardreportsNAM 2018nam 2019
Jacek J. avatar image
Jacek J. answered ·
I like Kris idea with calculated metrics, and here's example simple implementation:
Average HTTP errors per day metric is just a calculated column, my formula is very simple, it's just dividing sum of errors by 30, as shown below:
Whole report's definition in attachment: AVG daily HTTP errors per month.zip
Share
Kris Z. avatar image
Kris Z. answered ·
If I understand you correctly, you need to divide the number you have by number of days in a month. If this is correct, then it looks like a custom metric definition.
Share
