question
Alexander R. avatar image
Alexander R. asked ·
AMD services not starting: /usr/bin/chmod: cannot access ‘/sys/class/dmi/id/product_uuid’: No such file or directory
Hello.
for the 100-th time Customer can`t provide Linux with kickstart installer.
All packeges was installed and i have successfully installed AMD.
I have no missed deps or pkg`s.
The main problem is: AMD not starting:
ndstop & ndstart
Starting Dynatrace CVA Console Basic Analyzer...
-- Subject: Unit cba.service has begun start-up
Apr XXX chmod[26641]: /usr/bin/chmod: cannot access ‘/sys/class/dmi/id/product_uuid’: No such file or directory
Apr XXX chmod[26642]: /usr/bin/chmod: cannot access ‘/sys/class/dmi/id/product_uuid’: No such file or directory
In logs i have no error information. Status of service "activating"
Will be happy to accept any help.
Alexander
nam probe
1 comment
What version is this? If a supported version (2018 or 2019), open a support ticket and attach 'gather' archive to the ticket.
('gather' instructions: https://community.dynatrace.com/community/display/PUBDCRUM/DC+RUM+Data+Collection+Guide#DCRUMDataCollectionGuide-WhenRUMConsoleisdown )
-- Erik
0 Likes 0 · ·
1 Answer
Janusz D. avatar image
Janusz D. answered ·
Hi
Can you check if can RHEL OS determine machine's UUID:
Run command
[root@amdprobe ~]# dmidecode |grep -i uuid
Is the BIOS sharing host’s UUID ?
See https://bugzilla.redhat.com/show_bug.cgi?id=961906 ?
1 comment Share
Hello Janusz,
I have checked Product ID, Serial ID in Bios. It is not defined.
So I will update this settings and after that will update this topic.
Thank you for hint.
Alexander
0 Likes 0 · ·
