• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
      • BSM Open Q&A
  • Home /
  • Public Forums /
  • BSM Open Q&A /
avatar image
Question by McKenna J. · Dec 13, 2013 at 08:07 AM · server side scripting
One Transaction Multiple Applications
I have a case where one Synthetic Monitor will be checking the port, for example, on a database. This is one check, but validates the database availability on 3 applications.
I need to figure out the best way to manage this in BSM since if something were to happen to this database I would want to make sure each application referenced this check's Service Quality. I am not sure what the best idea is to take on this situation since I could either look for this check then make x amount of messages for each application. Another way might be to do something with SMT processing to link all together perhaps. I have a very small subset of situations that will be like this and there might be more later when we add more applications into BSM.
Any ideas or tips on the best way to manage this would be appreciated.
Comment
People who like this
0 Show 0
10 |2000 characters needed characters left characters exceeded
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
· Add your reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Michael L. · Dec 13, 2013 at 09:10 AM
Hi Jacob,
There are indeed a few ways to solve this. Let's go through the most obvious ones:
  1. If you are fetching the data using a script adaptor, like the mojo.dmi one, send several messages to the message translator with different application names.
    1. Pro: Quick.
    2. Con: Only possible when using a script adaptor and makes the service model bigger
  2. Create a message translator rule at the end of the message translator that changes the application name and ParameterId and sends several messages.
    1. Pro: Quick to implement; the message translator rules only get hit once.
    2. Con: Bigger service model
  3. Create a message translator rule that adds links from the applications to the service.
    1. Pro: Smaller service model; the message translator rules only get hit once.
    2. Con: Trickier to implement; only possible when there already is a service created, need to poll twice before the links are created after resetting the service model
  4. Create a post processing rule on the service model template that links the service up to the different applications.
  5. Manually change the service model to add the relation.
    1. Pro: Quick if the number of connections is low.
    2. Con: Needs to be redone every time the service model gets reset.
  6. Create a separate adaptor that links the transaction to the applications when polling.
    1. Pro: Smaller service model; the message translator rules only get hit once.  No need to change the message translator if you use the EUE adaptor.
    2. Con: Need to run separately from the other adaptor, adding a delay to the connecting when recreating the service model.
Personally I'd go for number 6 as I could handle the configuration externally without adding too much code into the polling of every message.Sure you could cache the configuration in the state object, but it would still impact the throughput of messages. I'd then create a csv file which tells the name of the transaction and the additional applications it should be linked to. The adaptor could then also be turned off when the service model was built out, not adding any overhead at all.
Kind regards,
Mike
Comment
0 Show 5 · Share
avatar image Michael L. · Dec 13, 2013 at 09:18 AM 0
Share
For completeness. If you're going down the road of using a script (adaptor, post processing or message translator) this is a good start.
var trx =
    Packages.com.proxima.centauri.servicemodel.ServiceModelAPI.createConfigChangeTransaction();
  try {
    var pId =
         Packages.com.proxima.centauri.servicemodel.common.AbstractService.makeValidId(ApplicationName);
    var cId =
         Packages.com.proxima.centauri.servicemodel.common.AbstractService.makeValidId(TransactionName);
      var newService = trx.modifyService(pId);
        _Logger.info("LinkServices", "Adding Component child: " + cId);
        newService.addComponentChild(cId);
        trx.commit();
  catch (ex) {
    _Logger.warn("LinkServices", "Configuration change failed: " + ex.message);
  finally {
    trx.close();
Good luck!
Mike
avatar image Alex N. Michael L. · Dec 16, 2013 at 05:17 AM 0
Share
we should wrapper the AbstractService.makeValidId function in mojo.service whenever a service id is used.
avatar image Michael L. Alex N. · Dec 16, 2013 at 05:19 AM 0
Share
If you use mojo you can use makeXML instead of the makeValidId function (smile)
Mike
avatar image McKenna J. · Dec 13, 2013 at 09:47 AM 0
Share
Thanks Mike!
I was doing 5 and started to have a fear of deleting the service model since it was difficult and slow to do. I will evaluate each since I have 100+ check total and ~12 of them fall under as troublemakers for this.
avatar image Alex N. · Dec 16, 2013 at 05:16 AM 0
Share
By the way this is the use case for a dependency expression, ie the application uses an external service as opposed to a component where the metric/alert is an element of the service.  That of course limits the options you have to roll up the quality and can get confusing quickly.
Either way (component or dependency) I would implement option 4 but rather than use a config transaction you can simply generate a message and send it to another MT, ie Service Templates where you add a rule to create a link.  The rule type is Service Relationship, add properties for ParentID, ChildID and Type (Component or Dependency) and add a second action to apply the changes.  If there are many changes to make you can use the MT as a single transaction as well and just send a single commit once all processing is complete, synchronising on the correct event for this can be tricky as you don't know which event is the last and the poll finished event will arrive before the SMT is finished so I have implemented this as a scheduled event in  the past to see if any commits are needed.
I'd also delete all the rules in that MT beforehand as they are not applicable (since 11.1).  Do it in the XML restart the service (or send this message #ChannelFrom=Command|CommandTarget=ServiceTemplates|Command=LoadConfiguration)
If the service model is large I'd steer clear of options that duplicate services (options 1 and 2)
Note: In 12.1 there is a feature called Rule Editor that would be ideal for this but its a bit buggy and should be avoided until its patched so you must do this with post processing rules.
There is also a link function in mojo.service
avatar image
Answer by Alex N. · Dec 16, 2013 at 05:26 AM
That's what I thought at first but we don't know if the implementations are the same and my guess is the SMT uses the implementation from makeValidId so we should use the same or we might get incorrect ids generated.
Comment
0 Show 0 · Share
Your answer
Hint: You can notify a user about this post by typing @username
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
Welcome to the
Dynatrace Community Forums
Check out the Forum User Guide and Forum Guidelines to learn how to get started.
Community Member of the Month
February 2019
Announcing Dynatrace's Community Member of the Month for February 2019, Larry R.! Click here to read more!
Employee Member of the Month
February 2019
Announcing Dynatrace's Employee Member of the Month for February 2019, Dave M.! Click here to read more!
Live webinar: AIOps done right through enhanced Dynatrace AI root cause detection
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
NAM 2019 Beta is available
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Related Questions
Accessing anonymous _Message properties 6 Answers
Loading 3rd party classes into OSGi 0 Answers
Aggregating site metrics from EUE Connections 1 Answer
vCenter Adapter User Requirments 0 Answers
Scripting data calls to the web server 2 Answers
Forum Tags
server side scripting web development service model
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
    • BSM Open Q&A
