• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Network Application Monitoring /
  • NAM Open Q&A /
avatar image
Question by Carlos R. · Dec 03, 2013 at 04:30 PM · configuration esm
Files "Transdata" folder DBVAS. ClientVantage
MRs:
The following files are on the server clientVantage
mean these files?
can be deleted?
the path where the files are:
C: \ Program Files (x86) \ Compuware \ ClientVantage \ Data \ DBVAS
Comment
People who like this
0 Show 1
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
avatar image Carlos R. · Dec 03, 2013 at 04:36 PM 0
Share
I Clientvantage integrated with CAS
I have Version 12.0.1
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Benjamin W. · Dec 04, 2013 at 03:36 AM
Hi Carlos,
these files are used to transfer the results from ClientVantage / Synthetic Monitoring to the CAS. You can open the files in a text editor and you'll see they contain your SyM measurement results in a format readable for the CAS.
I would recommend against deleting them manually, because by default, they are deleted automatically after 7 days.
If disk space is an issue, you can change the setting in the SyM Console in the Agent Manager configuration dialog in the "Files" tab in the "CAS Collection data" group. You can set the number of days this data should be kept here (default is 7) to a lower value.
Please also take a look at the Console Help before changing any of these values.
Comment
Ulf T.
1 Show 2 · Share
avatar image Carlos R. · Dec 04, 2013 at 08:29 AM 0
Share
thanks for the reply
data effectively to save the information for nearly 365 days,
The question is, how these data are only to be sent to the CAS and that information is stored in the database?
if I delete that information should not be deleted from the CAS database right?
this is my current setup
saludos.
CCarrasco
avatar image Benjamin W. · Dec 04, 2013 at 09:50 AM 0
Share
365 days is a very high value for this setting, I would recommend lowering that value.
Once the data is in the CAS database, these files can be deleted. The data will remain in the CAS database even if these files are deleted.
The default setting is 7 days, which means that the CAS has 7 days to pick up the data and write it into the CAS database. If the connection between the Agent Manager and the CAS breaks down, you have 7 days to restore the connection without having a gap in your measurements. I doubt that you will go for 365 days without the CAS being able to connect to the Agent Manager, so your current value is very high.
Again, once the data is in the CAS database, it is not needed here anymore.
avatar image
Answer by Rich K. · Oct 05, 2017 at 01:09 PM
Hi Kalle,
All files which has .xmf or .xml as file extension will move to the folders.
But there are more folders. The Agent Manager will keep screenshots at C:\ProgramData\Compuware\Synthetic Monitoring\Data\ScreenShots folder.
If your version is earlier than 12.4 and you are still using a VantageView as reporting system, all alert files will move to c:\ProgramData\Compuware\Synthetic Monitoring\Data\Dumps\Alert-Queue folder.
Comment
Kalle L.
1 Show 1 · Share
avatar image Kalle L. · Oct 05, 2017 at 01:19 PM 0
Share
Great, thanks for the info!
avatar image
Answer by Rich K. · Oct 04, 2017 at 02:08 PM
All files from agents will moved to the child Agent Manager's 'Synthetic Monitoring\Data\SQF' folder, then the files will move to the 'Synthetic Monitoring\Data\dbproc\SQF\Parent SQF' folder.
Only you can see some files in the 'Synthetic Monitoring\Data\dbproc\SQF' folder when the Synthetic Monitoring DB is installed on the child Agent Manager.
If you did not install the DB on the child Agent Manager, there is a possibility that the registry has incorrect values. In this case, our support team needs to look at your machine, or you can send the support data from the child Agent Manager to the support team.
Comment
Kalle L.
1 Show 1 · Share
avatar image Kalle L. · Oct 04, 2017 at 04:18 PM 0
Share
Thank you! Very useful information :) So to summarize, does this look correct?
For the Agent Manager, monitor the amount of files in these directories:
C:\ProgramData\Compuware\Synthetic Monitoring\Data\DBVAS
C:\ProgramData\Compuware\Synthetic Monitoring\Data\SQF
C:\ProgramData\Compuware\Synthetic Monitoring\Data\dbproc\SQF
And for the Child Agent Manager:
C:\ProgramData\Compuware\Synthetic Monitoring\Data\dbproc\sqf\Parent SQF
avatar image
Answer by Rich K. · Oct 04, 2017 at 01:46 PM
If Synthetic Monitoring database installation is omitted on the child Agent Manager, the transdata files will not be created on the child Agent Manager. Instead all files will move to the parent Agent Manager and CAS will get the transdata from the parent Agent Manager.
Comment
0 Show 1 · Share
avatar image Kalle L. · Oct 04, 2017 at 01:52 PM 0
Share
Correct, but the raw data files (CPM_TR*.xmf) from each Agent will still appear on the Child Agent Manager before they're forwarded to the parent, and those xmf files go under the folders [...]\Synthetic Monitoring\Data\SQF and [...]\Synthetic Monitoring\Data\dbproc\SQF. This is important to understand e.g. when troubleshooting why monitoring data doesn't appear at CAS.
avatar image
Answer by Kalle L. · Oct 02, 2017 at 12:49 PM
I've noticed that my Child Agent Manager DBVAS directory is empty, only the parent AM is buffering data there. Does the Child AM buffer data somewhere, in case the connection between Parent / Child is broken for a while?
Comment
0 Show 1 · Share
avatar image Kalle L. · Oct 03, 2017 at 09:09 AM 0
Share
To answer my own question, I believe the data is buffered to the SQF folder. I don't suppose this is documented anywhere? The only article I could find related to this is about importing external data:
https://community.dynatrace.com/community/display/ENTSYM125/Viewing+External+Data+in+CAS+Reports
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Related Questions
Publish scripts and config to agent-initiated communication robot
ESM identify who is my first, second, Third..... and N Transactions in my transaction list
Managing ESM agents
How to mass update the scripting framework without publishing the entire TestPartner DB?
Enterprise synthetic -OnDemandDumps
Forum Tags
esm siebel Dynatrace Managed license nam probe wan citrix dna rest api configuration mq alerting NAM 2018 dashboard dcrumadvisory reports css nam universal decode database mobileapp RUM ads sap nam console scripting nam server sequence transactions nam 2019 upgrade
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
