question
Mohammed I. avatar image
Mohammed I. asked ·
Chrome Browser Support ?
does the recorder support Chrome Browser
Regards
Ibrahim
esm
Yuriy L. avatar image
Yuriy L. answered ·
I see this discussion is keeping going on for a while.
With Enterprise Synthetic Recorder you can script against any application you can see on the Windows desktop with different level of easiness (or difficulty). For Chrome recognizing HTML controls and capturing text is not available (but the text can be obtained through OCR or clipboard). I recommend reviewing Monitoring Applications with Un-recognized Controls article – it has a brief summary of how monitoring Chrome and other “difficult” applications can be approached.
Thank you,
Yuriy
Share
chao w. avatar image
chao w. answered ·
Does the Agent Recorder (Enterprise Synthetic12.5)has support for Chrome Browser?
Share
Matthieu B. avatar image
Matthieu B. answered ·
Hi all,
Orange group (more than 100 SMPE agents) is know pushing alternative browsers usage (Firefox, Chrome and Opera as well).
Thus, It seems reasonable to include Chrome at least within supported browsers list if it fits our development roadmap of course.
Matt
1 comment Share
Does the Agent Recorder (ClientVantage) has support for Chrome Browser ??
1 Like 1 · ·
Benjamin W. avatar image
Benjamin W. answered ·
Hi David,
if I understand it correctly, the question has not been about the Gomez Recorder, but about the Agent Recorder (this section is for Synthetic Monitoring Enterprise (formerly ClientVantage)), not Gomez SaaS.
The two recorders have similar names, but are quite different actually.
Hope that clears things up a bit,
Benjamin
Share
David M. avatar image
David M. answered ·
Hi Ibrahim, Solmaz,
I have just come across this post while searching for another answer, can I check that you are referring to the Gomez Recorder having Chrome support?
If this is the case then we are currently supporting chrome with the latest version of the recorder which can be downloaded from this link: Gomez Recorder
I hope this helps.  Thanks,
David
1 comment Share
Hi David,
Oh it seems I've posted on the wrong forum! I was looking for chrome support for Dynatrace browser agent.
thanks,
Solmaz
0 Likes 0 · ·
Solmaz A. avatar image
Solmaz A. answered ·
Hi Mark,
Is there a way we could push this request? Most of our users are using Chrome to interact with our site and I would like to emulate the same browser in my test scenario.
thanks,
Solmaz
Share
Whatmore M. avatar image
Whatmore M. answered ·
Hi Ibrahim,
We support IE and Firefox only and unfortunately we have no plans to support Chrome in the foreseeable future
From our online doc:  Working with Web Browsers
regards
Mark
Share
