question
Carlos R. avatar image
Carlos R. asked ·
Montoring SAP-GUI with Recorder(ex-Testpartner) of Synthetic Monitoring
hi, guys
i need help, well.. when i record a script for SAP GUI (client-Server app) is OK, but when test the script or public(Prudccition mode)  script (Deploy), the script working very SLOW!,
I don't know why happend this. the script working very slow and the same robot monitoring a web app i don't happend the same, the web page script monitoring working fine.
why happend this, the script working very slow?
thanks for your help.
ccarrasco
esm
1 Answer
Yuriy L. avatar image
Yuriy L. answered ·
@Carlos Carrasco
The slowness of SAP-related scripts created by the Recorder is normal. If you use such scripts, you can pretty much only monitor the availability of certain components of your application; time measurements generally do not allow monitoring response times. You would get better speed of execution if you create scripts using SAP recorder and then execute them in the Recorder, as described in
Monitoring SAP Applications
1 comment Share
thanks! for you help!, i was create script with the record SAP scripting and that is the solution for monitring SAP-GUI version 7.2.
greatings
0 Likes 0 · ·
