Resolved! Classic dashboards - service health with dynamic filter tag 111 Views 5 replies 0 kudos dashboards classic
ActiveGate directory disappeared, but it is still running 59 Views 1 replies 1 kudos activegate extensions
DSFM Metric 'Active Gate - Communication - Messages - Dropped' 46 Views 1 replies 0 kudos activegate dynatrace saas metrics
deep monitoring of process java disabled by rule 57 35 Views 1 replies 0 kudos deep monitoring processes services
Resolved! Tagging Kubernetes Clusters, Workloads, and Pods 11393 Views 31 replies 4 kudos kubernetes tagging
Resolved! How to disable redundant modules on ActiveGate 46 Views 1 replies 0 kudos activegate dynatrace saas
Api detection rules for using in memory profiling use cases 24 Views 0 replies 0 kudos alerting memory service analysis
How to use ActiveGate as a beacon forwarder in SaaS deployment 35 Views 0 replies 0 kudos activegate dynatrace saas real user monitoring
REST API -OAuth Authentication Failed with status code 400 133 Views 0 replies 0 kudos Bad Request in REST API Request Bearer Token from the Dynatrace SSO system
Configure IBM MQ extension in OneAgent instead of ActiveGate 181 Views 1 replies 0 kudos extensions ibm mq
SSL Certificate Monitor extension - monitor and alert only necessary Certs 231 Views 1 replies 0 kudos extensions ssl
Ideal or recommended way of monitoring processes in container 302 Views 9 replies 1 kudos container docker oneagent
App Metric injest - Request failed: {"code":403,"message":"Missing required permission."} 73 Views 0 replies 0 kudos custom app data ingest
