question
Uzair H. avatar image
Uzair H. asked ·
Enterprise Synthetic Manager installation throws DB Error
Friends,
Do we know why am I getting DB error when trying to install Enterprise Synthetic Manager 12.04.5. It says Password incorrect even though it's working fine while accessing other Dynatrace components.
Thanks & Regards,
Uzair
esm
Benjamin W. avatar image
Benjamin W. answered ·
Is the error message "Failed to Connect to <Your DB Server>. Please check your password and try again."?
If so, could you give the database user you're using the “db_datareader” role for the “master” database in SQL Server and try again?
Share
Frans S. avatar image
Frans S. answered ·
Tagging this question, because ran into this trying to apply Agent Manager 12.3.6 on 12.3.3.
Could not continue.
Share
