question
Carlos R. avatar image
Carlos R. asked ·
upgrade Recorder and agent ESM 12.2 to 12.3.6 problem with UserModifiableFunctions.XML
when upgrade the Agent with recorder, you need upgrade the framework and import the file.
but only can find the frameworkupdates.xml
in the folder "Framework Updates" only have frameworkupdates.xml
C:\Program Files (x86)\Compuware\Synthetic Monitoring\Recorder\Framework Updates
where is the UserModifiableFunctions.XML, because this update frame not come with this modulo and when try to star or play a script file, this can run because say something with functions usertakeprintscreen.
esmscripting
1 Answer
Yuriy L. avatar image
Yuriy L. answered ·
@Carlos C.
Hi Carlos,
I agree, this is an inconsistency. Historically in older releases Framework updates were available on the Agent Manager only. At later releases UserModifiableFunctions are also available on the Agent in, by default, C:\Program Files (x86)\Compuware\Synthetic Monitoring\Recorder\Framework Updates folder. In all releases that include the Framework, files related to Framework update can be found on the Agent Manager in C:\Program Files (x86)\Compuware\Synthetic Monitoring\Recorder\Framework Updates folder.
Just-in-case, if any changes has been made to user modifiable functions, you will need to merge existing module with what comes with the FrameWork updated using a code merging tool, like WinMerge. I’d also like to warn you that if you decide to find the tool on your own, please be aware of many pages in the Internet that interpret “merge” as concatenation, which, of course, brings wrong results.
Thank you,
Yuriy
Share
