question
Daniel B. avatar image
Daniel B. asked ·
DC-rum > ESM > Understanding reports
Hello Forum !
I don't understand how is calculated the application performance percentage of a transaction on a ES site. I am attaching 2 screenshots, one showing my ESM transaction config, and one showing the report screen. There is for sure a wrong configuration, I would appreciate any feedback.
  • I have created a ESM scenario running 4 transactions.
  • I have defined for each transaction thresholds on the Agent manager.
  • I get a summary availability of 100% and a summary performance at 0%.
  • Pointing the first transaction, I see that app performance reports 0%, despite that transaction has realized 26.4s.
  • Furthermore, on the attached screenshot, we can see that resquests is reported to 20. what are these request, are we talking about the numbers of click actions ?
To summarize my question, how are calculated availability, performance, and also, on what request count is based.
Daniel
nam serveresm
Carol O. avatar image
Carol O. answered ·
Hi, Daniel. Thank you for your post. You will find more information in Enterprise Synthetic - Site performance report.
  • The count of 20 should be from your 4 transactions running 5 times each.
  • The 100% availability means that 100% (all) of your (20) transactions were available, within that threshold.
  • The 0% performance means that 0% (none) of your (20) transactions were performing well, all were over the performance threshold. This percentage is about the number of transactions rather than the percentage of the measurement itself.
I hope this answers your questions. If you have additional reporting questions, I can send this to the CAS team.
Share
Daniel B. answered ·
Hello @Carol O.
Thanks for your answer. I have adjusted my thresholds and get better results.
I was thinking that it is possible to get in percentage the gain of time under the threshold, which is more useful ( meaning, if I have set a threshold set at 10s and got 9s run, my performance should be 110%, and if I am up to the 10s, for example 12s, my performance should be 80%)
I am searching in the documentation more info about how to interpret ES standard reports, and don't find it, maybe you can help ?
Furthermore, I am attaching a out of the box ES - Transaction list report: how should I interpret the graphic bars Transaction Time / breakdown (yellow/ brown) ? why, under Network Analysis Time / Network column, I see values both in milliseconds and in hours ? Same question for failed transaction time / Network column. The maximum time the transaction set will take to run is 3,5 mn in the worst case, so I don't understand these values in hours (highlighted in red).transaction-list-with-network-time.png
I also don't understand the blue bars "HTTP errors over time" timeout, is that mean that we haven't received any http error code or that I am closing the script running before receiving an HTTP status ?
For sure my customer will ask these questions, I prefer to be prepared.
Thanks for your help
Daniel
1 comment Share
Hi, Daniel. I am glad that the thresholds helped. You now have several questions for the CAS. I would encourage you to open a support ticket for the CAS. Thanks.
0 Likes 0 · ·
