question
Kalle L. avatar image
Kalle L. asked ·
How to mass update the scripting framework without publishing the entire TestPartner DB?
We have a shared monitoring environment where the "master scripting agent" idea cannot be used, since all the agents monitor different apps and as such have unique TestPartner databases as well. The process for upgrading the scripting framework assumes that the FrameworkUpdates.xml is imported to the master agent, and then published to all other agents. Is there any way to just publish the latest version of FrameworkUpdates.xml to all agents, without publishing the entire TestPartner DB?
Not sure honestly why the framework isn't automatically upgraded for each agent during service pack installation - why have this separate process for it?
Br,
Kalle
configurationesmscripting
Yuriy L. avatar image
Yuriy L. answered ·
@Kalle L.
Hi Kalle,
You probably know this, JIC. Files that are necessary for the Framework updates are already present on the agent in, by default, C:\Program Files (x86)\Compuware\Synthetic Monitoring\Recorder\Framework Updates folder. You can use user data publishing for delivering your own xml files. But, you are right, currently there is no option to automate importing into the Recorder database. This is why I suggested that you post your proposed improvements in DC RUM Product Ideas forum. DC RUM Product Ideas forum is being closely monitored by our product management, whereas this forum discusses using the existing product features.
Thank you,
Yuriy
2 comments Share
Thanks Yuriy, I'll definitely post an RFE regarding this. And good point about the XML file already being there, so you don't need to transfer it per each agent... But you do need to import it manually.
0 Likes 0 · ·
Yuriy L. answered ·
@Kalle L.
Hi Kalle,
I think it was your customer’s wrong decision to have different Recorder databases on different agents. I think the proper way of addressing this situation would be creation of the database that would contain all the scripting assets. Necessity to develop different scripting assets on different machines does not preclude from having a "master scripting database". If the database would be maintained on a specific machine, it could still be considered a "master scripting agent".
I see the following major aspects of creating such database:
  • Exporting assets from the individual databases and importing them into the master database. For text assets (scripts, modules, shared modules) "copy and paste" could be an alternative.
  • Merging user modifiable functions and user created modules and shared modules.
  • Resolving naming conflicts. This might be pertinent to both the names of the assets and to the names used in user modifiable functions and in user created modules and shared modules.
It might make sense to use one of the databases as a starting point. Also, It might make sense addressing naming conflict in individual databases and making sure the scripts still work prior to bringing the assets to the master database. And, of course, saving intermediate results – things might not work right away.
Having one scripting database should be beneficial to your customer from many points of view: assets sharing, code sharing, and, of course, that they will need to update only one DB.
I cannot be more specific without seeing what your customer has. Please feel free to post any additional questions.
You might also like to post your thoughts in DC RUM Product Ideas forum.
Thank you,
Yuriy
1 comment Share
Hi Yuriy,
Thanks for the response! I may have worded the "shared environment" a bit ambiguously, what I meant is that since we're a managed service provider, there are several different customers within one DC RUM environment. So as such, it's not a single customer's decision on how to implement this; agents are located within different customer subnets monitoring only a specific customer's apps, so the idea to have a single master agent is not really possible to accomplish.
I suppose there are two enhancement ideas that come to mind:
1. The ability to publish an xml file that is imported for selected agents. Since the current method only supports copypasting the TestPartner DB to the agent (thus overwriting the old one), this would require some work to also automate the asset importing.
2. The framework could be updated along with the regular agent recorder update - is there some reason why this isn't done automatically?
0 Likes 0 · ·
