question
Murali D. avatar image
Murali D. asked ·
where does Enterprise synthetic data stores in DB and How to take Enterprise synthetic Database backup
Ernest J. avatar image
Ernest J. answered ·
The default path is: Program Files (x86)\Microsoft SQL Server\MSSQL12.MSSQLSERVER\MSSQL\DATA
Share
Hello Murali,
Please clarify your question. Are you just asking where our database files are stored on the database server? Your DBA should be able to find this; you may have modified this during the database install. Do you need the default path? Thanks!
Share
