question
Per B. avatar image
Per B. asked ·
Agent Upgrade from 12.4 to 12.5.3
We are planning to upgrade our ESM from 12.4.xx to 12.5.3.
As it's at big installation we need to know if it's possible to upgrade in steps (is the agent backwards compatible ?)
Which combinations will work, of the below configuration :
Agent AM . CAS
12.4.5 . 12.4.5 . 12.4.15 . Current Setup !!
12.5.3 . 12.4.5 12.4.15 ??
12.4.5 . 12.5.3 . 12.4.15 ??
12.5.3 . 12.5.3 . 12.4.15 ??
Hope for a quick reply :-)
esm
Carol O. avatar image
Carol O. answered ·
Yes, so these would work:
Agent . AM . CAS
12.4.5 . 12.5.3 . 2017
12.5.3 . 12.5.3 . 2017
Share
Matthew K. avatar image
Matthew K. answered ·
Agents can be behind on releases of the Agent Manager. As Karolina pointed out above... Please note that DC RUM 2017 May release is required as a component of the complete ESM 12.5 setup
Share
Karolina L. avatar image
Karolina L. answered ·
ESM 12.5 requires RUM Console and CAS of the 2017 release. You should upgrade your ESM installation to the 12.5 release after your DC RUM 2017 is up and running. See the Upgrade checklist here: ESM upgrade checklist
Karolina
Share
