question
Kalle L. avatar image
Kalle L. asked ·
Troubleshooting Recorder slowness
I'm looking for any tips in pinpointing why the Agent Recorder (12.5.3) init process for script executions is slow. After pressing the play button for any script, it takes about a minute before the section >>>Initializing the Application variables...<<< begins. That is the first entry in the work log, so I can't see what's taking so long / what's possibly timing out before that.
This started after we migrated two Agents by cloning them. The other one works normally, and the other one has this issue. It's not really that critical since everything basically works, but it's somewhat annoying to wait 1+ minute before each test begins.
esm
1 Answer
Yuriy L. avatar image
Yuriy L. answered ·
Hi Kalle,
This problem requires a more careful investigation than what is possible through the Forum, so please open a support ticket.
Thank you,
Yuriy
Share
