Mulesoft Cloudhub
arild_palencia2
Inactive
Hi.
Is it possible for Dynatrace SaaS to analyse applications deployed on MuleSoft Cloudhub (https://www.mulesoft.com/platform/saas/cloudhub-ipaas-cloud-based-integration)? Cloudhub is based on Amazon AWS buy fully managed by Mulesoft..
Please provide guidelines if possible.
Regards Arild
5 REPLIES 5
michael_kopp
Dynatrace Champion
Dynatrace Champion
As it is neither possible to install the agent nor to set JVM parameters this does not look to be possible.
Dynatrace would still see requests from a monitored JVM to MuleSoft CloudHub, but not into it. To achieve this MuleSoft Cloudhub would at the minimum need to allow adding jvm parameters and deploying arbitrary binaries
Ok, thank you! Would you recommend to use AppMon for the purpose of seeing the requests from a monitored JVM to MuleSoft Cloudhub?
This would not make a difference. the fundamental problem is that as far as I can see one cannot define JVM options. If that is possible then both products could be made to work.
manav_goel
Inactive
Can you monitor applications deployed in Mulesoft Cloudhub.
Community Team
Community Team
New topic with more up-to-date answers:
How to integrate Dynatrace with Mulesoft
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
