How to change email address for problem notification from dynatrace team to cutome
suyal_d
Inactive
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Hi @daya s.
I am sorry, right now thats a fixed sender that is used by our problem notifications. Is there any specific use-case you would like to solve by changing the sender?
To create an email filter you can use the free text subject field and enter any textual hint.
Best regards,
Wolfgang
