Monitoring PaaS component
srinivas_krish2
Newcomer
Hi, With the SaaS model of dynatrace we have the option of setting up the monitoring for PaaS web app application. Is there a way to monitor other PaaS components such as PaaS SQL DB, PaaS Redis Cache etc on Azure?
Srini
martin_gutenbr1
Dynatrace Helper
Dynatrace Helper
Hi Srini,
Thanks for your question!
PaaS databases, like SQL Server and Document DB (when used with the MongoDB driver) can be monitored, when OneAgent monitors the application that's accessing it.
The same goes for Azure Storage, Service Bus, etc, but to a different level of degree for each of these.
Plus, we're actively working on improving our Azure support, so we will be able to offer additional insights for the upcoming releases.
Hope that helps,
Martin
