Mongo DB Monitoring User Privileges
bernhard_madlma
Participant
trying to configure the Beta Plugin "Mongo DB" for Dynatrace Managed.
Which role and/or privileges does this DB monitoring user need?
Regards
Bernhard
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
have you seen our blog post by @Karolina R ?
https://www.dynatrace.com/blog/enhanced-mongodb-mo...
Prerequisites
  • MongoDB 2.6 (or higher)
  • Ruxit Agent 1.89 (or higher)
  • Privileges: User must have the clusterMonitor role for the admin database.
Senior Product Manager,
Dynatrace Managed expert
